When encoding the wedding of my cousin to avi, the subtitle disappear after abouth 1 hour.
I also tryed with Handbreake, Here the subtitle stays, but the audio disappear.....
I have ripped with MTR....
Results 1 to 9 of 9
I'm having a similar problem. I have an avi with idx/sub files which play fine in under the Filter Tab /Preview but when trying to burn, the Info box in Progress says:
SUB: Could not determine file format
Cannot load subtitles: /Users/movie.sub.....
And it continues to encode with no subs. Should I try to to convert the sub/idx file to something else?
idx/sub are not burnable unless if DVD mpeg2enc and "Decode with mplayer" option are used (you shall select the idx file).
I didn't quite understand what you wrote. Are you saying they are not burnable unless I am burning to DVD? Burning to mpeg2?
If either of those two are the case, is there a way that you know to convert the idx/sub to a format that ffmpegX can use?
Yes, I meant that only the "DVD mpeg2enc" target format with "Decode with mplayer" option enabled in the Options tab can handle burning of subtitles in idx/sub format.
There is no known way to convert idx/sub to anything else on OSX.
subtitle issue when re-encoding..
By tsh in forum Newbie / General discussionsReplies: 2Last Post: 3rd Feb 2011, 00:26 -
Subtitle encoding (same mashine) and identifiying
By vidm in forum SubtitleReplies: 1Last Post: 9th Jun 2010, 16:21 -
Hard drives disappear
By rhegedus in forum ComputerReplies: 12Last Post: 20th Sep 2008, 05:03 -
subs disappear
By bountylord in forum SubtitleReplies: 0Last Post: 21st Feb 2008, 09:32 -
Encoding a DivX with bigger subtitle.
By Ashernor in forum ffmpegX general discussionReplies: 6Last Post: 5th Jan 2008, 16:29
