I am new at all of this so dont be to hard on me, ok what I am tring to do is put a mpeg to dvd, I have download a couple of videos that are mpegs, but what program do I need to use to do this? I tried everything it seems like you have to change the mpeg to something else like to a jpeg or am I way off. I dont know just thought I would ask someone in here if they know how to do this or could explain how??
There's a HOW TO section on the left to start with <--------
https://www.videohelp.com/convert
You need a program like tmpgenc that convert your source to mpeg 2 (dvd mode). Then you can "author" that into a dvd structure for burning. The authoring program, like ulead dvd movie factory, is what is used to make menus and the like. Then you get two folders to burn - a video_ts folder and a audio_ts folder. They go on the dvd. You don't have to see that, most authoring programs can burn the folders for you so you don't have to find it.
Do a little more reading so you get comfortable with it and when you have some more specific questions feel free to come back and we'll try to help.
EDIT - I didn't see that they already are mpegs. Chances are you can already author them. Load them into an authoring program like ulead dvd movie factory. It will tell you if they are in dvd format or not. If they are you can go ahead and make menu and author it. If it isn't dvd ready than you have to convert it.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
If you just want to watch the video on TV you can try burning the MPEG file on an ISO data DVD. Some DVD players can play these.
If you want to have a DVD that will work on just about any DVD player you need to "author" it. It may not be necessary to re-encode your MPEG file, it could be DVD compatible already.
If you need to re-encode you can use just about any MPEG encoder program (TMPGEnc Plus, Cinema Craft Encoder, etc). Most all-in-one DVD packages can encode and master -- Ulead DVD MovieFactory, NeroVision Express, etc. They generally don't do quite as good a job, or at least aren't as flexible, as using separate programs for each function.
Quick Question
By TagFan in forum DVB / IPTVReplies: 3Last Post: 26th Sep 2011, 10:45 -
Quick AVIdemux question!
By janlafata in forum EditingReplies: 16Last Post: 17th Mar 2009, 02:19 -
Quick laptop tv out question
By Tidy in forum ComputerReplies: 3Last Post: 28th Jul 2008, 15:42 -
quick question?
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2008, 17:38 -
Quick Question
By Scryer_360 in forum Newbie / General discussionsReplies: 3Last Post: 26th Dec 2007, 08:21
