Hello,
I'm looking for some sort of SOFT plastic cover sleeves, both in the size for DVD cases and in the size for CD cases.
Please note that I don't mean sleeves that I put the discs only in, and I don't mean the plastic sleeves that requires me to take the DVD's cover pages out of their cases in order to fit them in the protective sleeves. Also, I don't mean the re-sealable plastics known as "seal king".
I simply mean some sort of plastic protective sleeve that will fit the WHOLE dvd case (and also one that will fit a whole CD case). I know this exists, because I have seen it in the past, they sometimes store DVDs and CDs in these type of protective covers in 2nd hand stores.
There used to be this style of protective sleeves in LP format for vinyl records years ago (made out of the same type of plastic that I'm looking for in DVD/CD size).
What I want to know is where I can buy these in bulk.
Does anyone know what kind of protective sleeves I'm talking about?
Thankful for any help.
Since you don't say where on the entire planet you live, I'll assume you're in England and would suggest these are probably what you're after:
http://svp.co.uk/products-solo.php?pid=288
http://svp.co.uk/products-solo.php?pid=280
... since they pretty much fit the description.
Scanning cds and dvds
By mccoady in forum MediaReplies: 10Last Post: 3rd Aug 2024, 03:13 -
Longevity of CDs and DVDs? Are my old CDs starting to lose it?
By garybeck in forum DVD & Blu-ray RecordersReplies: 15Last Post: 25th Jan 2013, 14:38 -
Are plastic sleeves good for DVds?
By cynikalhedonist in forum MediaReplies: 10Last Post: 28th Feb 2011, 02:12 -
Nero works with CDs not with DVDs
By fiiido in forum DVD & Blu-ray WritersReplies: 13Last Post: 23rd May 2008, 04:44 -
can write CDs okay but not DVDs
By johnsees in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 22:13
