There are two ogm clips I have. I want to cut a part of the first one then join it with the second one using Virtualdubmod. When I do this I get this error.
An out-of-bounds memory access (access violation) occurred in module 'VirtualDubMod'.
I have tried to join the two original clips and that worked. I also joined the cut file and the second file to an avi clip, but there are subtitles I would lie to keep that don't show up. The problem only occurs when I join the cut clip and the second clip too an ogm or mkv file. I clecked help and it said the problem might be with the codecs. I have the ACE mega codec pack and no combination of codec worked.
crashinfo.txt
Results 1 to 1 of 1
Splitting/cutting/joining MP4 accurately...
By The.King in forum EditingReplies: 2Last Post: 2nd Nov 2011, 12:35 -
need help cutting and joining avi files in virtualdub
By granturissimus in forum EditingReplies: 3Last Post: 31st Jan 2011, 02:53 -
Easiest software for compilation, cutting/joining?
By jiopi in forum EditingReplies: 0Last Post: 14th Oct 2010, 12:31 -
Simple MPEG2 Cutting/Joining Question
By thefiddler in forum EditingReplies: 4Last Post: 21st Dec 2009, 15:39 -
WMV cutting-joining-playback problems
By Cusem in forum EditingReplies: 2Last Post: 7th Dec 2007, 03:48
