As the title says really...I have 6 Digital 8 Tapes which I have used just once. All the footage now has been archived onto (many) DVD's.
To cut costs I wouldnt mind using these same tapes again to record a new project.
So the bottom line... will there be any generation loss or will the image appear as if it were a new tape?
Just my opinion but I wouldn't reuse them. Tapes are cheap, but the video is invaluable. Did you back up the footage to DVD as DV-AVI or did you encode it to DVD spec and therefore make it unsuitable for future editing?
Having said that, there shouldn't be any degradation in re-using the tapes a reasonable number of times."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
I agree, the contents of the tape, no matter how mundane (SP) are far more valuable than a new tape.
Each time you use a tape there will be a slight degrade, depending on your tape you may get 4 or forty reuses before you can notice even a small degradeIS IT SUPPOSED TO SMOKE LIKE THAT? -
Sometimes after I've put them on my harddrive and made DVD's, I reused them. I haven't noticed any degradation in quality after the 2nd use. I suspect that old or stretched tapes might have problems.
Cheers for the info guys, what I did was export it to the computer as DV-AVI and then split it into files so I could burn it as data onto DVD. Im going to buy new tapes for my new project though but as a second back up, im going to get into the habit of backing it up onto DVD as well (just in case
tapes can be reused, however they do degrade with use. After a few goes you may start to experience image break up - squares or lines where the previous recording show through is a usual sign - at which time you need to bin the tape. I agree with the other posters here though, keep them as an archive.
Read my blog here.
Putting them on a DVD as DV is in my opinion an excellent idea, though I doubt that many actually do it. This all kind of goes back to archiving not really being a one time step, buy rather a constant process.
Best way to convert analog 8mm tapes to digital
By charliedog in forum Newbie / General discussionsReplies: 7Last Post: 29th Nov 2011, 03:15 -
Converting old 8mm tapes to digital..help!
By MrMister007 in forum Capturing and VCRReplies: 7Last Post: 4th Aug 2011, 23:59 -
Convert VHS tapes to digital files
By Rogerwodehouse in forum MacReplies: 5Last Post: 20th Jul 2011, 15:55 -
Converting Analog Hi8 tapes to Digital to PC
By Dicka24 in forum Capturing and VCRReplies: 9Last Post: 4th Jan 2011, 13:07 -
HD Mini DV tapes to Digital
By oriopn5150 in forum Newbie / General discussionsReplies: 11Last Post: 3rd Aug 2010, 20:26
