I used the btirate calculator to use TMPGenc to convert my avi and mpg files to DVD complaint. My total files are 2hrs 22min 46sec. It said to use 4075 bitrate with 192 kbits/sec for the audio. When I put 4075 = 105.6% of capacity? What does that mean? Does that mean it wont fit on a dvd-r when I burn it and I will have to dvd shrink it?
Whats the difference if I set the percent capacity to 100% = 3849 bitrate and use this instead of the 4075. I think the bitrate calc is always off, giving me over-capacity. Can someone comment on why?
so 4075 would be fine even if its 105% capacity? I dont think you know how big it is until AFTER you output everything.
Are you using TMPGEnc Xpress, If so I'd just let it set the bitrate automatic by choosing DVD5 and then change it to 102% size as that always has fit for me.
Plan on a lot more space if you're going to do motion menus. It will also add a lot time to your processing time as well.Originally Posted by redwudzDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Yep, that would be fine if you wanted it to fit the disc down to the very last MB, and provided that TMPGEnc could be accurate down to the last MB. However, as others have said, depending on what you want in terms of menus, it might be advisable to round down and use the round figre of 4000kbps, and this should allow you to include a basic still menu.Originally Posted by jyeh74If in doubt, Google it.
bfg "lifetime warranties" bite the dust
By aedipuss in forum ComputerReplies: 0Last Post: 16th Aug 2010, 08:01 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 11:26 -
mp3 bite rate to dvd .vob file
By koskofam in forum Newbie / General discussionsReplies: 7Last Post: 20th Nov 2008, 11:39 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48 -
Bitrate Calc Question
By cquetsch in forum Newbie / General discussionsReplies: 6Last Post: 24th Jun 2007, 19:11
