On my DVD there are several videos and the menu in 720x576.
But there is one video in 480x576. The video runs smoothly without any problems, but e.g. if I want to show the DVD on my TV (via overlay) it totally messes up the display.
Is there any command that I can put there (or any other advices) in order to avoid that?
480x576 is not a legal resolution for DVD. You might be able to use DVD Patcher (set the header's resolution to 720x576) to trick the DVD player into playing the video without reencoding.
Change VOB Resolution
By Simmons in forum Video ConversionReplies: 4Last Post: 30th Aug 2011, 07:37 -
Change video resolution
By Browneyd in forum EditingReplies: 5Last Post: 11th Jan 2011, 10:34 -
Change resolution from 235:1 to 16:9
By ThaiJan in forum Newbie / General discussionsReplies: 4Last Post: 9th Apr 2010, 14:16 -
How do I change video Resolution
By mmkk in forum Video ConversionReplies: 7Last Post: 31st Aug 2009, 17:33 -
Change resolution without recompressing?
By StoneGold in forum Video ConversionReplies: 9Last Post: 30th Sep 2007, 08:02
