I just converted an avi file to mpeg2 using TMPEcn, loading a template to DVD (NTSC), then did all the authoring on DVD Lab, when I tested the disc on my home DVD player it plays normally but the image is to large for my TV and the edges are not visible.
When I was converting them to VCD I used CENTER (CUSTOM SIZE) 316 x 216 pixels on TMPEnc to fix this problem. Can I use the same size for a DVD or is it another size?
Video with custom frame size
By caio1985 in forum ffmpegX general discussionReplies: 1Last Post: 7th Aug 2010, 18:08 -
Custom file size using Avidemux not saving properly.
By Xaiphong in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2010, 01:27 -
Editing custom frame size video - portrait/vertical VGA - 480 x 640
By PMESKA in forum Newbie / General discussionsReplies: 2Last Post: 12th Mar 2010, 07:02 -
Formatting AVCHD into mp4 custom size
By shoegirl in forum MacReplies: 4Last Post: 1st Mar 2010, 18:03 -
Re-encoding avi [to custom size]
By nic3 in forum Video ConversionReplies: 2Last Post: 30th Aug 2009, 04:53
