What remote control should I buy for my MCE 2005 setup? Thanks!
do you want IR or RF? Do you want to do anything 'tricky' or just the regular volume/play/pause etc etc.
If you are running MCE, you will need a MCE certified video card and it should come with a remote control, or have it as an option from the card manufacturer. Microsoft doesn't want you to build a MCE system, they want you to buy it complete, so they are not much help.
Personally, I would pass on the MCE OS and just use XP.
If by this you mean 'capture card' then yes...there "should" to be mce drivers for it, but since MCE is basically xp sp2 you can get older cap cards to work as well. Personally, I love the MCE interface, and have tried them all before settling on it. Well, maybe not all, but most of the popular ones, including free/trial versions of paid for. If you are fine with IR, just get the MCE remote for approx 35$ from pcalchemy.com.you will need a MCE certified video card
Not sure what the Harmony 520 is capable of, but if it does not interface with the PC via IR recieiver/transmitter than it won't help you any.
However I dont use it for MCE
Which remote?
By Alomonger Pete in forum DVD & Blu-ray PlayersReplies: 4Last Post: 2nd Jan 2009, 09:13 -
remote codes?
By pamelajaye in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2008, 12:45 -
Re-program your remote
By zoobie in forum ProgrammingReplies: 0Last Post: 4th Nov 2008, 14:28 -
Remote
By WildParadise in forum Media Center PC / MediaCentersReplies: 14Last Post: 24th Apr 2008, 11:10 -
remote
By rtrg in forum Newbie / General discussionsReplies: 1Last Post: 1st Apr 2008, 14:46
