Hi,
I've tried various tools but never found an easy way to do this:
I'd like to rip some scenes from a dvd to mpeg. I don't need the whole dvd just some scenes. I've got some dvds where I'd like to rip scenes so I'm looking for an easy way to do this.
Can anyone help me out?
A ripping tool, where you could set the scenes you want and then just rip it to mpg would be great. An avi file would also work.
fairuse wizard for avi divx/xvid, select start and stop and convert, you need the full version.
dvd shrink in reauthor mode to cut exactly what you want, output to a video_ts folder and then use vob2mpeg to get a mpeg2...or just use the vob directly, it may work fine in many tools.
or open the dvd vobs directly with videoredo and edit and output as a mpg.
or tmpgenc dvd author and edit and reauthor directly from a dvd.
if it is a commercial disc you can use anydvd in the background to remove the encryption. -
thx
I just found out about a tool called aoa dvd ripper which does basically everything I want -
I've had good luck with the Fairuse tool. The video comes out great looking too.
I have a simliar question - I have a DVD a friend authored some time ago consisting of home shot footage. He has provided me some new footage to add to the DVD, but much of the material needs to come from the original DVD which he no longer has the source for, So I need to extract the bits I need from the DVD.
How do I extract the mpeg2 streams from his dvd, put them into my NLE (Sony Vegas), shuffle things around, then export back to my DVD authoring program (Sony DVDA) without losing quality?
I tried AutoGK (creates avi's) and Cinematize (appears to transcode? to quicktime - quality seems to suffer)
should I use vob2mpeg? videoredo?
thanks!
-dave -
nm - answered my own question I think - tried videoredoplus and it seems to work flawlessly.
thanks,
-dave
Easiest way to cut and join video files
By zammil in forum Newbie / General discussionsReplies: 8Last Post: 15th Oct 2010, 12:04 -
What's the quickest/easiest way to cut something from DVD and DivX
By dsajkw in forum EditingReplies: 2Last Post: 2nd Sep 2010, 11:50 -
With a mac how do I convert a Final Cut Express item to mpeg2 dvd?
By dagardenguy in forum ffmpegX general discussionReplies: 2Last Post: 16th Jan 2009, 12:00 -
best, easiest way to cut bad section out of vob file
By dblake2 in forum EditingReplies: 2Last Post: 16th May 2008, 17:53 -
what is the easiest software to cut an audio file?
By marlo in forum Newbie / General discussionsReplies: 2Last Post: 2nd May 2008, 13:45
