Oh and I forgot to say the files are IFO, BUP and VOB, so I don't need any conversion from avi or anything, just a tool to author them and create a nice menu. Thanks
What you have is already authored, even if it doesn't have a menu.
Simple to use - tmpgenc dvd author. somewhat limited in templates and styles. relatively cheap
More complex - DVD Workshop 2. More freedom, much more powerful, much more expensive
Complex - DVD Lab Pro. Steeper learning curve, cheaper than DWS2. Lots of freedom.
I don't of anything that follows the iDVD route for windows, but look at DWS2. You can get demos for all three, although DWS2's demo is pretty knobbled, whereas the others are fully functioning.Read my blog here.
Thanks so much for your help. I tried Ulead first, but I find it rather clumsy to work with and it wouldn't do what I needed it to do. So I ended up downloading DVD lab Pro which seems to be exactly what I need. I got one problem though and I can't figure it out. I've created the menu, added and linked the movies and then compiled the DVD. When I use the simuation in the menu it works and the menu is also set on 'inf' for duration, but when I compile the files and then try to play them from my harddisk, the menu only appears for a second or so and then the it stops. Anyone know why or what to do?
Thanks! -
If you burn it to a rw dvd and put it into your dvdplayer or dvd-rom it should be fine. When I create menus and then play the dvd in windvd from my harddrive samething happens to me. If I burn it to a dvd it is 100% fine.
What We Do In Life, Echoes In Eternity.... -
Thanks so much! I did burn it and as you suggested it worked without a problem.
Adding a menu to a DVD of music videos with no menu
By vtrop in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2009, 09:07 -
Make menu for a movie dvd that have subtitle and have not any Menu!
By p_samimi in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2009, 14:29 -
DVD Menu with Chapter and Menu Template.
By big-boo in forum Authoring (DVD)Replies: 3Last Post: 17th Mar 2008, 06:20 -
dvd menu and sub menu program
By mikeoliver1313 in forum Authoring (DVD)Replies: 7Last Post: 20th Jan 2008, 11:31 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
