Hi. I successfully burned a DVD using Roxio, and would like to know how to merge the 2 DVDs into one. Each disc contains less than an hour of saved footages so I'd like to put them in one disc. I don't know what specific software I need to use; much less, how to do it. I have Nero, Roxio, DVDShrink, DVD Decripter. If that is helpful. PS: Would it be best to back them up first then combine the Video_TS? Your help will be greatly appreciated.
You might take a look here: https://forum.videohelp.com/viewtopic.php?t=284279
Also look to the 'AUTHOR' guides to the left. <<<<<< -
Thank you for the link. I am relieved to know I am on the right track
I used DVD Shrink to transcode but I don't understand why the first disc does not show Title 1 which is the main feature. Only title 2 appears. I have no problem with Disc 2. It has both the main feature and extra.
Merging 2 mkvs into one
By leoficz in forum Video ConversionReplies: 8Last Post: 19th Apr 2012, 07:31 -
Merging files
By drtbray in forum EditingReplies: 12Last Post: 13th Apr 2012, 17:08 -
MKVToolnix merging help
By SunnyHours in forum MacReplies: 7Last Post: 2nd Dec 2010, 16:39 -
MKV merging help
By snadge in forum Video ConversionReplies: 0Last Post: 25th Oct 2009, 14:19 -
Problems Merging DVDs
By npjs31 in forum Newbie / General discussionsReplies: 2Last Post: 29th Feb 2008, 03:44
