Results 1 to 9 of 9
  1. This might be an unusual one. Struggling to convert my camera clips to MPEG2 for DVD
    I can PLAY the AVI perfectly in Media Player Classic (uses FFDShow)
    I can PLAY with WMP9 (it reports using ffdshow MPEG-4 Video Decoder)
    BUT
    Windows XP does NOT provide a thumbnail preview (well it does but it is black)
    When I load into VirtualDub it doesn't show the Video. I had thought maybe I could decompress to encode the thing as MPEG2
    When I load into Boilsofts AVI to VCD it shows the video in preview window but I get black video in the resulting MPG.
    Same with Ulead DVD MovieFactory
    Any ideas PLEASE?
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Maybe try using an AVISynth script, which could be as simple as:
    AVISource("c:\clips\clip.avi")
    And opening this in virtualdub ? (After installing AVISynth, naturally)
    If in doubt, Google it.
    Nov 2002
    GSpot...
  4. Originally Posted by kschang
    OK so gSpot tells me its MJPG and it could render it.. with ffDshow which I already knew... but it changed nothing. I tried also using FourCC changer but no joy....
    Will try AVIsynth shortly
  5. I am leaning towards a Canon A700, that do 640x480 30fps video. Why shouldn't we use TMPGENC to encode to mpeg ?
  6. SingSing... offtopic mate!!!!
    AVIsynth barfs....AVIsource couldnt locate a decompressor for fourcc mjpg (D:test.avs, line1) but of course ffdshow DOES work it out.. hence I can PLAY but not convert... so what file do I need to install methinks???
    Feb 2004
    Pleasant Hill, CA
    Have you looked at the AviSynth documentation? A quick search for "MJPEG" turns up some help at:
    http://www.avisynth.org/AviSource
    near the bottom. Two possible solutions, plus a link for more info.
    Good luck,
    Jim
  8. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Canon MJPEG avi movies open directly in Windows Movie Maker, ULead Video Studio, Pinnacle Studio, etc.
    Mine opens directly in Virtualdub but the MJPG_Mainconcept Video V3.2.4 codec that Virtualdub is using was probably loaded from a different editor.
  9. Thanks... I DLed the Morjan MJPG codec and I can now at least convert them.... god knows what changed on my system but at least I am working (sort of!)
