I am going through a computer upgrade right now, and I am just starting to get my video encoding capabilities back to where they were before I started. Unfortunately, I am having a problem with MPEG-2 playback in WMP10 that I can't quite manage to sort out.
For some reason, when I play back MPEG-2 files in WMP10, the color is shifted vertically in relation to the video. The files all play fine in Nero Showtime, and they play fine on my set top DVD player. I am using the MPEG-2 codec that I used in my previous setup, so I'm pretty sure its not a codec issue. Having ruled that out, I'm not sure what else I should be looking for.
Regards,
D.W.
Unless you have some overpowering reason to use WMP, I would just dump it and use a different player. Alternately, you could go to Microsoft's site and see if they list the problem. Or go back a version to WMP9 or lower and see if they have the same problem. I suspect your codec is not compatible with WMP10, though it may work on everything else.
I use VLC and Zoom player. VLC doesn't need installed codecs and Zoom (The payware version) has lots of settings to customize the program. Media Player Classic is another good choice.
DV Video color space examples
By peg in forum Newbie / General discussionsReplies: 0Last Post: 15th Apr 2012, 18:59 -
Black space on bottom and left/video shifted?
By divergex in forum Newbie / General discussionsReplies: 4Last Post: 30th Jun 2009, 20:32 -
Color shift in ffmpeg X - ffmpegX native color space and gamma?
By rbot1980 in forum ffmpegX general discussionReplies: 0Last Post: 2nd Feb 2009, 21:16 -
Color space question
By mourya in forum ProgrammingReplies: 2Last Post: 22nd Dec 2008, 19:08 -
How do I know what color space I'm working in...?
By Mickeyjuice in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2008, 01:28
