it suddenly happened !!
i have an ATI 9200.
i connected it to my VCR.
i got the sound but no video(picture) on my PC . when i click "record" it will capture sound only.
has any one came across such problem??
You might take a look at lordsmurf's site for ATI capturing info: http://digitalfaq.com/
This sounds like the same problem as https://forum.videohelp.com/viewtopic.php?p=1322587#1322587 Have you tried that solution again? -
Not enough details. Software? Settings?
software:
i tried to capture using ulead video studio and ati TV.
settingss:
capture to PAL B (my default) @ DVD resoultion.
ati TV doesnt give any detail while Ulead says that there is no input signal or signal unclear.
i will only be able to hear the sound but no pictures. -
I also have ATI 9200 and it can not capture - it is video (VGA) card.
Do you have ViVo version of this card or ATI All in wonder series?
If not what are you doing is connecting the card's video out to the VCR's video out - nothing will be captured of coarse. And sound is separate anyway...
More details on your part are needed as noted - brand, model, connections you did - everything! -
i have an all-in-wonder version of the card and i have used it several times to capture videos from vcr.
what i did was connecting my camcorder which has an AV OUT to my ati card through the connection box( ati famous purple AV and S-Video box).
Problem with sound - MP4 video from CD
By Ves in forum Newbie / General discussionsReplies: 5Last Post: 27th Jan 2012, 03:43 -
Corel Video Studio Pro X4 5.1 Sound Problem
By imported_kevsim in forum EditingReplies: 5Last Post: 13th Jun 2011, 18:15 -
[Problem]X264 and Premiere Pro CS4, no video, only sound?
By hdnine in forum EditingReplies: 3Last Post: 1st Apr 2011, 05:27 -
avi.NET sound problem in Interleaving AUDIO with VIDEO muxing
By ntiki in forum Video ConversionReplies: 4Last Post: 13th Mar 2010, 16:34 -
ADS Tech DVDXpress DX2 problem - video/sound not displaying
By DiamondJoe in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jan 2008, 14:21
