    May 2003
    Melbourne, Australia
    Hey,
    I Have a whole lot of Final Cut Express captured DV which i have happiliy been editing on my mac, but i want to do some stuff to it on my PC.
    What format is the captured DV in? I talking about the contents of th capture scratch folder. And is it openable on a pc if I add a file extension?
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Big picture: DV is a stream from the camcorder to tape or over IEEE-1394 (Firewire). The stream can be contained in a file wrapper and then treated as packet data for OS copy, or for networked file transfers.
    If you read out of the MAC file as a DV stream over IEEE-1394 firewire, the DV stream can be recorded back to tape or "captured" on the PC to a DV-AVI file and visa versa.
    A DV.dv file can be converted to a DV stream or a DV.avi file in Quicktime Pro if I'm remembering correctly.
    PS: Quicktime Pro spec isn't clear about export to DV-AVI.
    http://www.apple.com/quicktime/pro/specs.html
