So does higher mp3 bitrates take more battery power? If you have 320 bitrate instead of 128 or 64 kpbs??
Results 1 to 9 of 9
Hmm... anyone tested this theory??
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
From my experience, no.
I used to encode to 128 for my 256M player and got about 10 hrs (1 AA battery). I've done full capacity with 192, then with 320 and got about the same. The volume always stays the same, as well as continuous play (no skipping or jumping back and forth). -
Not really. Same for WMA vs MP3.
Never heard of that but it sounds logical since it has to do more processing. On the other hand I'd imagine turning the volume up even the slightest bit would have more affect on the battery life.
I read an article recently talking about how DRM protected audio files kill battery life more than non-DRM protected music, it didn't mention bitrates though.
Extra CPU cycles required to process higher bitrates have a small impact on battery life. If you have a hard drive based player then higher bitrate = larger file size = more power consumed spinning the hard drive = a noticable decrease in battery life. This is not an issue with flash based players.
DRM knocks battery life down by as much as 25%.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
The anti-DRM crowd ought to point that out to the tree hugger crowd.Originally Posted by drjtech
transcoding mp3 to higher bitrate questions
By spiritgumm in forum AudioReplies: 6Last Post: 28th May 2011, 17:46 -
Video file formats and battery life
By perdomot in forum Software PlayingReplies: 5Last Post: 5th Apr 2010, 08:18 -
preserve battery life: play video from hdd or flash drive?
By akrako1 in forum Software PlayingReplies: 1Last Post: 7th Jan 2010, 21:55 -
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 08:57 -
Good Battery Life
By Arlo in forum Portable VideoReplies: 2Last Post: 22nd Apr 2009, 14:52
