Hey just wondering what place you buy your Dvd Thinkpak cases (in the Usa)? I am looking for quality single and double thin dvd cases. I ordered some cases from Meritline and 80 percent of them were broken so I never brought anything from them again. I like the Nexpak Thin dvd cases but I wish they had a better hub holder like the push tab ones have.
www.usplastics.com is where I got mine.
Shop4tech has the flimsiest single and double cases. I'm guessing everyone who sells them for 25 cents and under are pretty much selling the same ones.
Have had great luck with the 4 and 6 disc cases from
Shop4tech, the 14mm and the 28mm ones.
They are basically the same case, minus the insert for
2 discs on the 4 disc cases.
Single Slims I get from Sams Club at $13 for 50.
They are Verbatim brand, and are pretty sturdy,
the discs stay in the rings ( they use the 3 clasp ring)."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
DVD Storage Cases
By Tenacguy in forum MediaReplies: 6Last Post: 10th May 2010, 19:43 -
50 pk slim DVD cases
By zoobie in forum MediaReplies: 0Last Post: 14th Feb 2010, 19:53 -
Bad DVD Cases?
By Nitro89 in forum MediaReplies: 3Last Post: 27th Feb 2009, 10:34 -
DVD/CD Jewel Cases
By wulf109 in forum Off topicReplies: 3Last Post: 23rd Jul 2008, 18:13 -
Double DVD Cases
By royal007 in forum MediaReplies: 0Last Post: 16th Aug 2007, 19:45
