Hi there.
I recently acquired a DVD recorder to convert all my old motorsport tapes onto disc. Unfortunately, there is a problem I have discovered.
Whilst the DVD's are recording fine and they play in my DVD recorder, they will not play on anything else: PC, Playstation, other DVD recorders etc.... This is a problem, because if my DVD recorder fails, I have nothing to play my DVD's on.
The discs aren't the issue I'm sure (Datawrite titanium) as I have used these before and they are a correct format for all my other DVD playeing equipment.
So it must be something to do with the DVD recorder, although I don't know obviously.
My recorder is a Panasonic DMR-ES20D by the way.
Anybody know what's wrong?
"No thank you very much! I'm going to get some sultanas! Hmph!"
Zippy -
Is that done manually?
How would you do that?"No thank you very much! I'm going to get some sultanas! Hmph!"
Zippy -
Ah, found it. What a legend.
Thanks for your help, simple as it was!
What a donkey I am! hehehe..."No thank you very much! I'm going to get some sultanas! Hmph!"
Zippy
Recording issues with LG DVB-T HDD/DVD Recorder RHT497H
By Geex360 in forum DVB / IPTVReplies: 1Last Post: 22nd Feb 2010, 10:43 -
Magnovox/Funai 2160 recorder; video AGC issues. Suggestion for a TBC
By videobruce in forum DVD & Blu-ray RecordersReplies: 7Last Post: 13th Jul 2009, 13:24 -
DVD Recorder - Quality Issues (NOT PC TYPE)
By jaffacaique in forum Video Streaming DownloadingReplies: 11Last Post: 1st Apr 2009, 16:45 -
Sony DVD recorder and lip sync issues
By zdamons in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Jan 2008, 14:56 -
Disk burning issues with Toshiba HDD Recorder
By leafslover in forum DVD & Blu-ray RecordersReplies: 1Last Post: 18th Sep 2007, 00:39
