  1. Member vhelp's Avatar
    Mar 2001
    New York
    Morning all.
    RE: WinMX and DVD rips of VCD sample clips
    I still looking for good quality DVD rips of samples done in VCD format.
    I've seem most on here, and I've D/L'ed some
    elsewhere, and coupled with my newly found WinMX file D/L'er
    app i've mananged to find quite a few .mov and .avi samples
    mostly. Anyways...
    In my quest to find a suitable D/L and file sharing server
    AND messing around with VCD's AND searching for VCD's to
    compare etc. I've come accross a couple of VCD's that seem
    to fair in good quality AND sharpness!
    Here's the VCD clips I stumbled accross so far, I've named
    them pretty easy for you to find, should you be using the
    WinMX app:
    "vhelp-1-The5thElement.mpg"
    "vhelp-2-The5thElement.mpg"
    ...else try 5thelement or 5th element
    I've found quite a bit this way.
    I hope to find more samples. Oh, I did find a sample clip
    on "Dogma" but the quality wasn't too good or worth mention
    ing here, and it was done at 320x240 - didn't work in my
    DVD player, but the two above played soo good! Even in
    my DVD app CinePlayer 1.0
    Should anyone find these two (and more) can you tell if it
    were a hardware based mpeg encoder that created these files
    or an expensive software type?
    I'll be on WinMX, so check them out. Oh, B4 I 4get, here is a link to D/L
    the WinMX app. ...case you don't have it.
    Well, if you find them, great. Play them, they'll be worth
    the D/L. You just gotta!!
    Check back w/ ya's later on.
    -vhelp
    <font size=-1>[ This Message was edited by: vhelp on 2002-01-02 07:59:18 ]</font>
  2. Banned
    Jan 2006
    US
    blablabla
    You are in breach of the forum rules and are being issued with a formal warning. no crap.
    / Moderator Baldrick
