Results 1 to 9 of 9
    Apr 2006
    Hey guys Okay i love the program.First i can't burn with nero for some reason it starts off to burn then errors threw away about 12 Dvd's already.So i make dvd without burning then i open nero and burn the dvd that way works okay.I have made numerous dvds that way no trouble or errors.Second problem i am running into is i get avi dvd rips setup a dvd with menus and all then i make dvd without burning of coarse all goes well. Then when i go to burn again with nero i get a compilation error and then can't burn.This is only lately happening.I used nero 7 went back to nero 6 cleanout everything before i install each version so i know it was a clean install still same problem.I have read that sometimes when avi's are made from dvd rips they loose some sort of compilation files.But it seem to be happening alot lately..Chris or anyone else can you please help me .Its okay to take care of one problem for me at a time.After all i had to wait a day to post this.
    Why use nero if it cause so much trouble? I would switch to convertxtodvd...at least try the demo. Or use the old free divxtodvd and just burn with nero or some other burning tool.
    Apr 2006
    First you ask why use nero if it gives me trouble Your last message was to burn with nero.That one lost me.Thanks for the reply but not helping.I said i t worked fine now all aof a sudden other problems im trying to pin point.
    Apr 2006
    Sorry two other thing i forgot one is after svcd2dvd finishes my machine will lock up and second sometimes it won't even launch nero.Just don't think its a nero problem totally.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    are you converting with svcd2dvd and burning with nero? then switch burning tool, to prassi ones! or wait for some nero gurus to post...i gave up nero a long time ago...
  6. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    That issue has been fixed for a couple of builds now. Update your copy of SVCD2DVD.
    If Nero is giving you so much grief, why not grab the excellent freeware ImgBurn and set SVCD2DVD up to use that.
    Apr 2006
    I Appreciate your fast replys,I didn't want to sound like a snippy guy im just stressed from these all of a sudden problems.Yes i do the conversion with svcd2dvd it goes good just when i try to burn i get a compilation error.Prassi wil burn vob files and set it up like nero.I used prassi back when there were no dvd burning or equiptment made it wasn't even a thought for the common user.Oops giving up my age LOL
    Apr 2006
    Chrissy i use the latest just dl last week.What about the compilation error after i convert avi with svcd2dvd when i try to burn
    Apr 2006
    Thanks guys hey chrissy i used ImgBurn worked great easy straight forward program..
    All problems solved thanks again guys
