Using Nero I burned 4 avi video clips into CD/R and played it in my dvd player (Philips DVP642/37) DIVX it did gave me a picture but with no audio. I'm trying to play AVI in my dvd player since it supports DIVX. I do have Virtual dub but I dont know how to encode it to get the audio. I do know that if I convert AVI to VCD it will work fine but i dont wanna do that since my dvd supports AVI. So what are my options what should I do to make this work? I dont have a dvd player I'm using CD/R.
One possibility is the audio is not interleaved in your avi clips. The reason is explained in the VDub Help/Audio interleaving.
Open a clip in VirtualDub and select direct stream copy for video and audio. It will creat a new file with the audio interleaved.
Just a thought,
Chas
Remote for Philips DVP642
By Melina in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Jun 2010, 22:54 -
Problem playing AVI on Philips DVP 642K
By yohu123 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 20th Aug 2007, 10:28 -
Philips DVP642 DivX subtitles. WORK!!!
By shrybouski in forum DVD & Blu-ray PlayersReplies: 22Last Post: 7th Aug 2007, 15:06 -
Output resolution for Philips DVP642
By cheerful in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Aug 2007, 00:41 -
Philips DVP642 and DivX 6/Ultra
By cheerful in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Aug 2007, 12:43
