god i'm such a noob![]()
anyway, only one of hundreds of .mkv files i've converted using S.U.P.E.R. (kicks ass man) is not synced after converting (though it is perfect unconvereted) by like a few seconds. Wait, another loses synch in the middle but catches up, weird. Yeah.. any noob-friendly freeware i could use without converting it to another, probably crappier, format?
pardon my noobness...(is that a word?)
Your description sounds like a corrupted video file. If it's missing some frames in the middle or at the beginning, that my be the cause of your sync problem. If you could open it in a video editor, like VirtualDub, you might be able to repair it, or at least improve the sync.
The original file may play properly because of the format it's in, though it is damaged. When you convert it, then the problem shows up.
BTW, are you converting to .mkv or from .mkv? What format do you want to end up with? -
i'm converting from .mkv to DivX .avi, and thanks to S.U.P.E.R. it is nearly lossless, i'll try that Virtual Dub when I get home, so in 30 min.
Need some help with a synch problem
By kotyczka in forum AudioReplies: 3Last Post: 10th Jul 2011, 07:26 -
Audio synch problems on an .avi file -noob
By ComicFan2 in forum ffmpegX general discussionReplies: 4Last Post: 18th Dec 2008, 12:47 -
A/V synch coming from .swf **noob warning**
By BrentsonAudio in forum ffmpegX general discussionReplies: 7Last Post: 17th Nov 2008, 17:47 -
Noob here, Compile Dvd problem!
By dbgt in forum Authoring (DVD)Replies: 3Last Post: 8th May 2008, 18:08 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 12th Jan 2008, 23:47
