Hello, im looking for a video encoder/decoder that converts large number of video files (wmv, avi, mpeg) because its annoying to have 10 converters to be sure that ill have the one that i need to convert that video. Is there an all-in-one video converter out there?
Didnt look if this question had all ready been asked.
Yes, this question seems to pop up frequently here. ConvertXtoDVD is perhaps the best "one-click" solution out there, doesn't cost much. There's an earlier free version still floating around, apparently. Not sure how much the mpeg2 encoding has improved since this older free version, if at all? There's freeware out there too, you have to experiment yourself to judge the quality differences.
But to do it properly, you need to frameserve these video files with avisynth into a high-quality mpeg2 encoder like HC, TMPGEnc, etc. You may need to install appropriate DirectShow filters onto your system - installing ffdshow got it all working for me (from the advice of this forum!). This way, too, you can add post-processing filters to your avisynth script to enhance the video quality.
If you're asking about batch converters, I think HC can do it. -
Then, it depends on what you want to convert to. AFAIK, ConvertXtoDVD is good if you want a DVD, not much else.
/Mats
iWisoft Free Video Converter producing blank (black) video?
By avideodummy in forum EditingReplies: 1Last Post: 8th Aug 2015, 11:55 -
Converting 5.2gb .mkv video to DVD5 using Any Video Converter Professional
By supersi in forum Video ConversionReplies: 1Last Post: 10th Dec 2011, 02:06 -
MPEG II Video Quality drops using Any Video Converter...
By Spoilerone in forum Video ConversionReplies: 9Last Post: 10th Feb 2011, 11:30 -
bad quality of camstudio recorded avi video merged by avs video converter
By shimi in forum EditingReplies: 5Last Post: 25th Feb 2010, 15:33 -
any video converters have video joiner+converter to convert 640x360 resolut
By bournurplusher in forum Video ConversionReplies: 1Last Post: 27th May 2009, 07:52
