Hi everybody,
I hope there are some Premiere-experts here, because I've got a very specific problem with my Adobe Premiere Pro 2.0. At the moment, I'm editing a show that I've captured with 3 camera's. I made a multicamera project, and everything works fine. Now, I'd like to add transitions between cuts from cam-to-cam. When I drag for example the 'cross disolve' over 2 parts on the timeline, nothing happens on the multicamera monitor. I'm aware of the fact that I should not see this on this monitor, butt I think there MUST be a way to see the effect, and adjust it, if possible.. I guess that the transition will work when I output the timeline to an .avi file or something, but that's WAY to difficult I guess.
Can anybody help me please!
Thx a lot!
Jens
I've upgraded to Premiere Pro 2.0 as well but I haven't started doing multicam editing. Have you asked your question over at http://www.adobeforums.com yet?
Tools used: ScenalyzerLive 4.0, Adobe Premiere Pro 2.0, Adobe After Effects 7.0 Professional, Adobe Encore DVD 2.0, IFOedit 0.96, DVD-lab PRO 1.53, Adobe Audition 2.0 -
No way to view the transitions in the Multicam monitor. Remember, the multicam monitor is not playing back your final edited sequence. It is playing back your original sources in one window.
multicamera editing in vegas pro 9
By anzimike in forum EditingReplies: 5Last Post: 29th Jul 2010, 22:25 -
multichannel audio with multicamera setup...
By foler in forum AudioReplies: 4Last Post: 7th Nov 2008, 01:57 -
multicamera - time syncronizing for split screen effect....
By foler in forum EditingReplies: 3Last Post: 6th Nov 2008, 16:04 -
Edting DVD high qualty
By niels_m in forum EditingReplies: 1Last Post: 9th Oct 2008, 08:41 -
DVD creation/edting with VISTA
By ronkleim in forum Authoring (DVD)Replies: 6Last Post: 27th May 2007, 01:07
