I have heard you can but I don't know how to! I'm such a novice at this stuff!
Check http://www.virtualdub.com for features. It is mainly used for editing AVI, but supposedly you can open MPEG1 files. No encoding features. Try TMPGEnc or LSX.
uhmm.. you dont want to do it that way...
use tmpgenc.. if you want you want you can frameserve from virtualdub (there are good reasons to do this.. virtual dubs resizer is better than tmpgencs, also frameserving solves most sync problems, and you can use virtual dubs filters, there are other good reasons as well). click the CONVERT link to the left and then the frameserve tab
i vaguely(sp) recall reading a way to do it with a certain codec.. maybe.. i might just have had my head in the glue bag too long. anyways.. there are too many good encoders out there to bother doing so hack job. use cce if you have a modern cpu or tmpgenc
No glue bag necessary, use DVMpeg for mpeg 1
http://rilanparty.com/vbb/showthread.php?s=&threadid=11368
or frameserve
http://www.vcdhelp.com/virtualdubframeserve.htm
jj
DVD -> Mpeg Streamclip -> Virtual Dub -> Premiere CS4 workflow. Help!
By BertRito in forum Newbie / General discussionsReplies: 11Last Post: 15th Jun 2011, 01:26 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
MPEG 2 TS (Transport Stream) in Virtual Dub MOD
By afcoff in forum Video ConversionReplies: 8Last Post: 28th May 2009, 09:58 -
using virtual dub to trim videos
By shashgo in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2008, 13:26 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36
