  1. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    I have read the guide for i-author on this side, and on the doom site, but I cannot find an answer to my question.
    Suppose I create a video file, and two audio files with TMPGEnc, how can I load them in i-author?
    The video file from CCE is supported, but not from TMPGEnc.
    TMPGEnc also creates mp2 files for audio. i-author can load them only in the first audio stream. The second audio stream supports only *ABS or *MPA files.
    Which program creates MPA files?
    I know that I can use BBmpeg for multiplexing, but this program does not support subtitles as i-author does.
    Can someone explain me how to solve this? as all the guides seems to avoid this topic.
    Thanks,
  2. Member adam's Avatar
    Sep 2000
    To load your audio streams into I-Author simply rename the ext to ABS or MPA. Make sure and tell windows not to hide known file exts (open any folder/tools/folder options/view.
    There is a new freeware program which can create soft encoded sub titles. I recommend multiplexing in bbmpeg and using this new prog to add your subs rather than using I-Author's multiplexor since it has some serious bugs. I can't remember the name of the new program but it should be pretty easy to find on doom9.org.
  3. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    Thanks for the response.
    I will search for that program.
    regards,
    The Dutchman
  4. is the new program for soft encoded subtitle called submux that can be found at dvd2svcd website?
  5. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    I suppose it is. I have not tried it yet
    The Dutchman
