Hi,
I have loads of cd's and each track is .cda file, well I would like to put these tracks on my IPOD NANO but have to covert to either WAV or MP3..
Can someone kindly recommend a program (pref freeware) which will enable me to do this?
If its not freeware its not that much of an issue however it is preferred in this case but not 1000% vital...
Thanks in advance...
Results 1 to 11 of 11
Try exact audio copy is freeware it's in the tool section will covert to either wav or mp3
Musicmatch
Slight aside: technically there's no such thing as a CDA file. CDA is just what Microsoft chose to represent CD audio tracks. In REALITY CD-AUDIO is a completely different format from the CD-ROM format (actually, CD-ROM format is a SUBSET of the CD-Audio format), but it's technical trivia you don't really need to know. -
Does it have to be WAV or MP3?
Why not just use ITunes, it's designed to work best with IPods. -
If you want mp3, iTunes doesn't exactly have the best mp3 encoder. aac/mp4 is fine though. Still not the best ripper either though.
All CD's and DVD's show up as an audio disc with track00.cda
By drew_2 in forum Software PlayingReplies: 3Last Post: 6th Sep 2010, 16:37 -
Query: Best way to go from a cda. file to plain PCM is ??????
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 6Last Post: 22nd Jun 2010, 20:46 -
Can't play audio CDs (.cda)
By kapow85 in forum ComputerReplies: 8Last Post: 1st Oct 2008, 03:47 -
How to copy/convert hidden DVD with only "Track01.cda" in dir
By vincehal in forum Newbie / General discussionsReplies: 9Last Post: 8th Nov 2007, 06:21
