I'm using nero to burn data and audio cds, and it keeps on failing at 7%. Does anyone know how to fix the problem? Maybe I should reinstall nero?
Also might try using a CD Laser cleaner on it first. Then Try uninstalling Nero. You could also try uninstalling the Drive, then reboot and let Windows reinstall it. How old is the drive?
What rootkits are running on your machine?
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
What Drive, hard drive, cd drive? how do I check how old it is?
And what are rootkits?
Pioneer DVR118L Won't Burn CDs
By DarrellS in forum DVD & Blu-ray WritersReplies: 17Last Post: 12th Apr 2011, 03:36 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
How to rip and burn (What to use for both) Karaoke Cds???? Please help. tha
By slayer_of_all in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2010, 20:30 -
Burn 2 CDs at once
By orfajackson in forum Newbie / General discussionsReplies: 2Last Post: 27th Apr 2009, 22:03 -
I can't burn CDs with iTunes.. What do i do?
By just in forum Newbie / General discussionsReplies: 9Last Post: 8th Dec 2008, 06:26
