hi, im looking for a site or program that can tell me what my graphics card is, what my ram is and all the other stuff, i thionk its an olf version of windows so it may be hard to just check like u would with win xp
p.s its a second hand computer im checking and not my primary, i ofcourse know what i have
SIW is my favorite. Gives you detailed info on the hardware of the computer and most all software on it.
http://www.download3k.com/SIW/Download-Free-siw.exe.html -
If you need drivers for hardware you need, this often helps:
http://www.drivermagic.com/p/nph-wizard.php
just download the Driver Wizard.
Have you tried
"Start> run> dxdiag"?
Dxdiag (Direct-X Diagnostic) will give you multiple pages of information about your computer. I know it works in Win 98SE and XP. -
I use Everest myself. Its a great program. Lots of detailed information on all things from installed equipment to fan speeds.
what conversion programs do most web sites use
By Magpye in forum Video ConversionReplies: 6Last Post: 24th Aug 2011, 11:53 -
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 17:51 -
Download Sites?
By wulf109 in forum ComputerReplies: 5Last Post: 8th Jul 2009, 19:19 -
Undesired sites
By Jomapil in forum ComputerReplies: 12Last Post: 15th Feb 2009, 15:09 -
Cannot Access certain sites
By dudesmn in forum ComputerReplies: 68Last Post: 8th May 2007, 17:46
