is it at all possible to join 2 or 3 avi files that have vbr audio, if so what progy and is there a guide for these progys, thanks.
Results 1 to 18 of 18
You could join them, but I doubt they would be in sync. Why not just re-encode the MP3 to CBR and avoid all the headaches? You could do that with VirtualDub, then join them easily afterwards with 'Append segment'.
Or you could try Virtualdub MP3 Freeze, it might be able to do it without sync problems. The latest VD says it can handle some VBR audio.
If you ever plan to encode the AVI to MPEG, you will probably have to change to CBR because few MPEG encoders can handle it.
There are many VD guides. Just look on the tool page below the program. -
Why join? If you're looking for convering it all to DVD there's no need to join the AVIs - let the authoring app take care of that.
/Mats -
Of course.
/Mats -
absolutley, that's what i intendOriginally Posted by jimmalenko
ok i'm gonna have to go with making a dvd of these to files how can i do this without having 2 files on the disk i would want the 2 added to run concurrently rather than playing 1 then having to play the other separatley
OK. Encode both to DVD-compliant MPEG and then in TDA, add them to the same track (one after the other). You may have to delete the chapter point created at the start of the 2nd file as some people have witnessed a slight pause (like a title change) in their DVD players when this is present.
If in doubt, Google it. -
One problem - TMPGEnc (as most encoders) doesn't like VBR audio - beware of sync probs!
/Mats -
so then i gotta make a vcd with 4800hz for audio and then add both to tmp express, is that right.
well i've saved the audio again as a wave so do i now go to tmp express and add both the files or just add 1 file and use the wave for the audio and what do i save it as, if i add 1 file and save as dvd then its going to be 4.2GB for just 1 of the files.
You need to learn how to configure tmpgenc xpress to use a bitrate so that both files will fit. https://www.videohelp.com/calc.htm should assist you with this, or you should just be able to tell xpress to use 50% of the disc capacity (so encode to a file around 2.1GB) for each file.
well i think i got something sorted out wll let you know when done, ussing tmp express with the wave files and added both the avi files and save taret a 1 xvid, from there on i can mess with the final output whether dvdr or untouched mpeg 4.
Why re-encode to XVID if you want this on DVD ? It means you'll have to re-encode again if you want it playable on a non-divx-compatible settop.
If you wanted one big AVI, redwudz nailed it days ago:
There never had to be any conversion of video at all if this is all you wanted.Why not just re-encode the MP3 to CBR and avoid all the headaches? You could do that with VirtualDub, then join them easily afterwards with 'Append segment'.
If you truly want this on DVD, output as DVD-compliant MPEG-2 and be done with it.If in doubt, Google it.
joining avi
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2010, 08:13 -
Joining avi files?
By tofuguy in forum EditingReplies: 4Last Post: 7th Oct 2008, 03:30 -
Joining avi's
By Frisco656565 in forum Video ConversionReplies: 5Last Post: 9th Sep 2008, 22:29 -
joining avi's
By php111 in forum EditingReplies: 15Last Post: 5th Aug 2007, 11:05 -
Joining two AVI's???
By Kayfabian in forum EditingReplies: 1Last Post: 17th May 2007, 19:07
