Hello.
I write a simple avs script that concatenates a couple of clips together. When I open it in wmp or mpc or even virtualDubMod it plays fine, but when I try to open it in virtualDub i throws "Cannot determine file type..."
The files:
video codec name = DivX 4(Open DivX)
stream Type = OpenDMLAVI
bitrate = 585kb/s
FPS = 25.00
and the script is:
AVISource("file1.avi", audio=false) +
AVISource("file2.avi", audio=false) +
AVISource("file3.avi", audio=false) +
AVISource("file4.avi", audio=false)
I tried searching in the forum but I didn't find a topic that covered this.
tks in advance for the help![]()
The codec IS installed, right?
Did you try DirectShowSource instead of AVISource? -
Aw man!!
It's been so long.....
Do you have it as an entire string??
If not, then you should have it like this
AVISource("file1.avi", audio=false) + \
AVISource("file2.avi", audio=false) + \
AVISource("file3.avi", audio=false) + \
AVISource("file4.avi", audio=false) -
kschang: I have the codec installed, I can play the avs in mpc, wmp and VirtualDubMod. And I tried with DirectShowSource and the result is the same.
pijetro: I have it all in one line, but thanks for the tipo :P
Its weird and I don't now how to deal with this problem. :\
edit: I can open the original files in VirtualDub, I just can't open he avs -
Not to sound anal here, but you don't seem to have the "\Path" of the .AVI file listed..
Copy and paste the exact .AVS file you have..
I've been burned on typos before.... -
Sorry for my slow replies, I havent had a change to be online very often. Anyway, here's the exact script:
AVISource("D:\clip01.avi", audio=false) + \
AVISource("D:\clip02.avi", audio=false) + \
AVISource("D:\clip03.avi", audio=false) + \
AVISource("D:\clip04.avi", audio=false)
Is it necessary to have so plugin or something extra installed in virtualDub folder or something like that? Because its weird, VirtualDubr is the only one that can't open the file :\
Thanks for the help -
What version of VirtualDub are you using? Have you tried an uninstall/reinstall of VDub?
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
Ok, so it turns out I was using VirtualDub 1.3c, the one with ASF/WMV support. I downloaded the wrong version
. And that was kind of dumb.
So I installed VirtualDub 1.6.14 and everything is working fine, thanks for the help.
Ripbot Can't open getinfo.avs
By kamranj in forum Newbie / General discussionsReplies: 3Last Post: 3rd Feb 2013, 17:43 -
Autogk Virtualdub AVS question.
By meneedit in forum Video ConversionReplies: 0Last Post: 9th Feb 2012, 05:31 -
Problem opening (.avs) file in virtualdub...
By dominator007 in forum DVD RippingReplies: 16Last Post: 19th Nov 2008, 11:53 -
Error with AVS and VirtualDub
By megakoolkid in forum Video ConversionReplies: 11Last Post: 23rd Aug 2008, 15:16 -
Problem with AVS file to open correctly in virtual dub and encode.
By vck in forum Video ConversionReplies: 9Last Post: 15th Aug 2008, 10:27
