Everything seemed to run fine. But the ISO is tiny and when I mount it there is nothing in the Audio or Video folders. What went wrong. Here is the log.
[3:55:29 PM] AVI2DVD Started !
[3:55:41 PM] Type mode : Avi Input
[3:55:41 PM] Output : Dvd
[3:55:41 PM] Encoder Selected : QuEnc
[3:55:41 PM] Start demuxing the AudioStream No.1 ...
[3:55:56 PM] Demuxing of the selected audio finished
successfully ! [F:\Movies\Compressed\Movies
Seen\Avi2dvd_temp\Extracted_Audio.mp3 96871824
Bytes]
[3:55:56 PM] Starts Audio correction ...
[3:56:57 PM] Audio Fixed successfully !
Seen\Avi2dvd_temp\Fixed_Audio01.mp3 96871824 Bytes]
[3:56:57 PM] Starts Mp3->Ac3 convertion ...
[4:03:10 PM] Audio converted in Ac3 successfully !
Seen\Avi2dvd_temp\AudioStream 1 MP3 2CH.ac3
332130816 Bytes]
[4:03:10 PM] Start creating avisynth script ...
[4:03:10 PM] Avisynth script created successfully !
Seen\Avi2dvd_temp\Avisynth_Script_File.avs 186 Bytes]
[4:03:10 PM] Bitrate used : 4790 Kbpps
[4:03:10 PM] Start video encoding ...
[7:34:26 PM] Video encoded successfully !
Seen\Avi2dvd_temp\Encoded_Video.m2v 3316565190
Bytes]
[7:34:26 PM] Pulldown of the m2v is starting ...
[7:40:10 PM] M2v pulldowned successfully !
[F:\Movies\COMPRE~1\MOVIES~1\AVI2DV~1\Pulldown
_Video.m2v 3316547584 Bytes]
[7:40:10 PM] Muxing Video+Audio(s) ...
[7:44:14 PM] M2v muxed successfully !
Seen\Avi2dvd_temp\Encoded_Video_Muxed.mpg
3734077440 Bytes]
[7:44:14 PM] Zero subtitles found
[7:44:14 PM] Author script generation ...
[7:44:14 PM] Author script generated successfully !
[7:44:14 PM] Start authoring ...
[7:44:19 PM] Dvd authored successfully ! [
F:\Movies\Compressed\Movies Seen\Avi2dvd_temp\DVD
[7:44:19 PM] Generating iso ...
[7:44:20 PM] Iso generated successfully ! This is the file
that you must burn --> [F:\Movies\Compressed\Movies
Seen\Avi2dvd_temp\DVD_Image.iso 866304 Bytes]
[7:44:20 PM] Job Done !!!
Results 91 to 96 of 96
Hello everybody!
I've got 1 (hopefully) easy question and 2 more difficult ones.
1. I've concerted a wmv-file successfully to a DVD by using Avi2Dvd. The created folder "Avi2dvd_temp" contains some files as well as another folder "DVD" which contains two more folders. One of them (AUDIO_TS) is empty whereas the other one (VIDEO_TS) contains the files I need to play my DVD.
Is it correct, that I only have to burn this Folder (VIDEO_TS) to my DVD-Disc and nothing else? I tried it and an my Notebook as well as on my PC it works properly. However, when I wanna play it with my DVD-Player on TV, it doesn't recognise the DVD as a DVD so it doesn't start playing the movie...
Does somebody know how to solve this problem?
2. I made a DVD Menu using PAINT.NET (recommendable program by the way).
My problem is that I did not really get how to put those unvisible boxes around the text I've written and I want to use for "Start Movie", "Open Chapter-List" or thins like this.
Could anyone explain this part to me agian please? I think the part with "put TINY markers" has to do with that?
3. My last question is about the Menu too. Is it possible to have a Main-Menu and a Chapter-Menu so that my Chapter Menu opens as soon as I click on "Chapter-List" in the Main Menu? And if I click on "back to main menu" in the Chapter-Menu, the Main Menu opens again?
In InterVideo WinDVD5 are two options when you click on "Menu". One is Main Menu and the other one Chapter Menu. So I'm pretty sure there must be a solution for this?!?
Thank you very much for your responses!!!
Remo -
Heres my LOG...
[11:50:58 PM] AVI2DVD Started !
[11:51:01 PM] Type mode : Avi Input
[11:51:01 PM] Output : Dvd
[11:51:01 PM] Encoder Selected : QuEnc
[11:51:01 PM] Start demuxing the AudioStream No.1 ...
[11:51:46 PM] Demuxing of the selected audio finished successfully ! [C:\Users\MIND BULL3TS\Videos\Seven Samurai\Avi2dvd_temp\Extracted_Audio.ac3 297606144 Bytes]
[11:51:46 PM] Starts Audio correction ...
[11:52:24 PM] Audio Fixed successfully ! [C:\Users\MIND BULL3TS\Videos\Seven Samurai\Avi2dvd_temp\Fixed_Audio01.ac3 297606144 Bytes]
[11:52:24 PM] Starts Ac3->Ac3 convertion ...
[11:52:25 PM] Audio converted in Ac3 successfully ! [C:\Users\MIND BULL3TS\Videos\Seven Samurai\Avi2dvd_temp\AudioStream 1 AC3 1CH.ac3 297606144 Bytes]
[11:52:25 PM] Start creating avisynth script ...
[11:52:25 PM] Avisynth script created successfully ! [C:\Users\MIND BULL3TS\Videos\Seven Samurai\Avi2dvd_temp\Avisynth_Script_File.avs 197 Bytes]
[11:52:27 PM] Bitrate used : 2695 Kbpps
[11:52:27 PM] Start video encoding ...
[3:13:27 AM] Video encoded successfully ! [C:\Users\MIND BULL3TS\Videos\Seven Samurai\Avi2dvd_temp\Encoded_Video.m2v 4176925347 Bytes]
[3:13:27 AM] Pulldown of the m2v is starting ...
[3:17:59 AM] M2v pulldowned successfully ! [C:\Users\MINDBU~1\Videos\SEVENS~1\AVI2DV~1\Pulldow n_Video.m2v 4176904192 Bytes]
[3:17:59 AM] Muxing Video+Audio(s) ...
[3:22:45 AM] M2v muxed successfully ! [C:\Users\MIND BULL3TS\Videos\Seven Samurai\Avi2dvd_temp\Encoded_Video_Muxed.mpg 4603045888 Bytes]
[3:22:45 AM] One subtitle found
[3:22:45 AM] Spumux script generation ...
[3:22:45 AM] Spumux script generated successfully !
[3:22:45 AM] Muxing the subtitle...
Avi2DVD froze here, and popped up with an error: FILE ACCESS DENIED
I ended up with this in my temp file: Uploaded Image = Screen Capture of temp files and frozen Avi2DVD
Is there anything I can do with the Encoded Video that is Audio Muxed but not Subtitle Muxed?
Or should I just try again?
I was thinking I should turn of UAC to let Avi2DVD have no trouble accessing the files...
screen%20capture.bmp -
I got the same problem must users have explained before :
here`s my log:
[08:06:41 p.m.] AVI2DVD Started !
[08:06:44 p.m.] Type mode : Avi Input
[08:06:44 p.m.] Output : Dvd
[08:06:44 p.m.] Encoder Selected : QuEnc
[08:06:44 p.m.] Start demuxing the AudioStream No.1 ...
[08:07:01 p.m.] Demuxing of the selected audio finished
successfully ! [C:\La casa de las dagas
voladoras\Avi2dvd_temp\Extracted_Audio.mp3 109455360
Bytes]
[08:07:01 p.m.] Starts Audio correction ...
[08:07:11 p.m.] Audio Fixed successfully ! [C:\La casa de
las dagas voladoras\Avi2dvd_temp\Fixed_Audio01.mp3
109454976 Bytes]
[08:07:11 p.m.] Starts Mp3->Ac3 convertion ...
[08:13:58 p.m.] Audio converted in Ac3 successfully !
voladoras\Avi2dvd_temp\AudioStream 1 MP3 2CH.ac3
328363008 Bytes]
[08:13:58 p.m.] Start creating avisynth script ...
[08:13:58 p.m.] Avisynth script created successfully ! [C:\La
casa de las dagas
voladoras\Avi2dvd_temp\Avisynth_Script_File.avs 197
Bytes]
[08:13:59 p.m.] Bitrate used : 4849 Kbpps
[08:13:59 p.m.] Start video encoding ...
[08:15:43 p.m.] Video encoded successfully ! [C:\La casa
de las dagas
voladoras\Avi2dvd_temp\Encoded_Video.m2v 0 Bytes]
[08:15:43 p.m.] Job NOT Done. There are warnings ... Find
at the log file the 0 byte generated file to focus where
exactly the problem appears
Can anyone help me please?
I can see the movie perfectly in WMP 11, the movie doesn`t have subtitles because the audio is in spanish so i do not need subtitles.
http://img515.imageshack.us/my.php?image=erroravisynthtb7.jpg -
Hmm interesting looking program. There's a really good built in encoder and a custom menu editor.
I'll try it out and see if will help me fit all of these episodes I have in with standard quality like DVD Flick's
It looks a little complicated though but its alright.
convert avi with subtitle files (.sub & .idx) into .m4v with soft subs?
By The Nemesis in forum Video ConversionReplies: 1Last Post: 6th Mar 2011, 21:40 -
avi2dvd menu is up only a few seconds.
By bman321 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2009, 22:45 -
Avi2dvd menu problems
By bman321 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2009, 20:18 -
Make menu for a movie dvd that have subtitle and have not any Menu!
By p_samimi in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2009, 15:29 -
Trying to convert AVI to DVD using AVI2DVD
By justmehere in forum Video ConversionReplies: 2Last Post: 22nd Jan 2009, 10:28
