ok, i tried making my first dvd- with mixed results! the source of my videos come from an analogue camcorder via a usb 2 video express. the results seem fine on the computer.
my video editing software is powerdirector.- so neway, made the dvd- but when played it- the dvd seems to play alittle slower than it should? as if it is missing some frames?? and also, i cannot access the main menu once the dvd has started playing! any help would be appreciated!!!
If you still have the MPEG-2s, try a different authoring program. TMPGEnc DVD Author is easy to use. For freeware, DVDAuthor GUI will work.
Have you successfully made DVDs with your burner and DVD discs before? I ask this to rule out burning/media problems. If you can use a program like DVDShrink and the burned DVDs work OK, then your problem seems to be either the MPEG-2 encoding or the authoring that is causing problems. If the MPEG-2s play properly on your computer and they are DVD compliant, then it sounds like an authoring problem. DVD compliant info:
https://www.videohelp.com/dvd
Authoring doesn't change the MPEG-2, just makes the DVD format and chapters, menus.
Another possibility with the menus is that your player doesn't understand your authored disc.
And welcome to our forums.
thanks- yea i have made dvd's before (copies), which turned out fine. i might try a different programe when authoring the dvd. thanks again for your help
Unable to access VIDEO_TS.info
By malestrom7 in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2009, 15:21 -
Unable to burn DVD, unable to access the Video_TS.ifo.
By Asymmetry in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2008, 00:02 -
Track Access / Menu Access
By chulew in forum Authoring (DVD)Replies: 3Last Post: 15th May 2008, 18:31 -
TMPGEnc Author Version 2.0 - Unable to make a DVD with a motion Menu
By tug_hill2 in forum Authoring (DVD)Replies: 5Last Post: 28th Sep 2007, 01:37 -
Need help with playing a DVD/Unable even after AnyDVD
By alegator in forum DVD & Blu-ray PlayersReplies: 8Last Post: 19th May 2007, 19:50
