I find Photo Story 3 easy to use and I built a test slide show with a voice over easily but I can not work out how to burn it to a DVD to view on a TV using Nero. When I click onto Properties it shows,"PhotoStory1.wp3"
I have read terms such as MVD but dont have the faintest idea how to save a PhotoStor 3 file in that format. Can anyone help?
DVD burning needs ifo, and vob files. WP3 must be a photo story 3 only format. You need to look for export to DVD, or at least to mpg.
You say that I need to look for export to DVD, or at least to mpg. Sorry to be so thick but how do I do that because I tried Instant Write Sony DVD + RW Drive (E) and all I got was.
"The file C:\Documents and Settings\Brian M Leahy\Desktop\PhotoStory2.wp3 is not a supported file type, and it cannot be imported into Windows Movie Maker."
So, how do I export to DVD and what does, "mpg" mean? -
http://www.estore.sonic.com/enu/photostory/default.asp
Looks like you need to buy a plugin. -
Kind of have to tell you that there is freeware on this site, that can produce photo slide show on DVD. The cost is $0.00. Click this: https://www.videohelp.com/~tin2tin/index.htm
I keyed "https://www.videohelp.com/~tin2tin/index.htm" and the following came up.
Produce and author DVD slideshows! 0.63 has been pulled thanks to a bug. Animate images.
I wonder if the bug is still there?
Convert Windows WVP2 (Photo Story) to any format on Mac
By der-mutt in forum MacReplies: 12Last Post: 7th Nov 2010, 19:24 -
Microsoft Photo Story 3 ?
By Mike99 in forum Authoring (DVD)Replies: 7Last Post: 21st Jun 2010, 03:40 -
Photo Story CD/DVD 8 by Magix - any users?
By Surber in forum Authoring (DVD)Replies: 1Last Post: 26th Jan 2010, 16:07 -
Using Magix Photo Story CD/DVD 8 to compile photos
By Surber in forum Newbie / General discussionsReplies: 1Last Post: 24th Jan 2010, 20:08 -
Alternatives to Photo Story
By Tchail in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 20:45
