Hi, I've been trying to add my own custom menu to a multiple title set using TitleWriter (I think it's supposed to do this). I can't figure out how to get this to work - the generic menus that come with it work fine. Anyone know how to do this? It would be great if there was a tutorial but none is listed.
Thanks,
Krel
Instead of browsing to folder containing generic browse to folder containing your menu.
Now TW needs to know which vts of menu needs to be imported to each target Vts
Dblclick on each vts entry you wish to change
Check Add Menu
Uncheck Menu Is Generic (This option checked may actually work better if Buttons in your custom menu Link directly to targets)
Check either Start with movie or menu (if generic is unchecked)
Hit Save Changes
Play your compiliation?? --
If menu failure -- the Happy face form can straighten out most problems -- You tell tw what the buttons actually are
If complete menu crash Zip up the menu. and post it (reduce with menushrink) only need Vide-ts.ifo,Video_ts.vob,Vts_??_0.ifo and VTS_??_0.vob files
Can you add custom thumbnail images in win 7 explorer?
By Rudyard in forum ComputerReplies: 0Last Post: 7th Jan 2011, 03:03 -
make mxf and add custom metadata
By zimbot in forum Video ConversionReplies: 0Last Post: 7th Jul 2010, 07:00 -
adding a Custom menu into a original menu
By Flarup in forum Authoring (DVD)Replies: 1Last Post: 30th Oct 2009, 09:38 -
Motion Menu with custom clips?
By chaosnovaxz in forum Authoring (DVD)Replies: 16Last Post: 14th Jan 2008, 10:49 -
Add custom sub to Thai dvd.
By chefen69 in forum SubtitleReplies: 1Last Post: 10th Nov 2007, 15:05
