okay someone told me "make sure you convert to NTSC or PAL depending on your current place of residence." i live in a suburb of california. what in the world does this mean?
It's very simple actually.
It's the different kinds of television signal standards. I don't know why exactly, for instance Europe and USA/Canada does not have the same standards, like you have 110V and we in Europe have 230 V in our power outlets.
Anyway, Europe has PAL and America has NTSC - including you ofcourse
It's good to know also, NTSC has a standard of 29,97 frames / second and a maximum capture resolution at 720x480. The standard VCD resolution for NTSC is 352x240, while PAL uses 25 fps and has a max capture resolution at 720x576.
So that's the way it is. Capture 29.97 fps and so on..
davidian - obviously overestimating himself -
Correct me if I wrong, but
If your source vid is PAL, it would be best not to convert to NTSC because u are adding frames in the convertion and may cause the final vid to be jerky when played. I have this problem converting some divx-PAL to mpg-NTSC.
I believe most dvd players will auto-play either, u just need to setup/choose what TV type u are outputing to.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34
