    Mar 2006
    First off, I am on a Mac, and I am burning with Toast 7.
    Okay, I have a four movies, in .avi, and they are thrown right into Quicktime...
    Out of 4 movies, two do not have sound in Quicktime, but the same two do have sound in VCL.
    the other movies, same format, have sound in Quicktime.
    I was wondering what I am missing, why these two movies will have audio in VCL player, but not in Quicktime.
    And when i burn these two onto a DVD using Toast7, there is no audio, but the other two work fine.
    any help, please!
    thanks,
    veganjustice
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    GSpot should be able to tell you what audio codec(s) are required / being used.
    If in doubt, Google it.
    Mar 2006
    I think that is only for Windows. I am running Mac
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Whoops ..... yes
    Mar 2006
    thank you though!
  6. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    VLC can also provide some information on audio/video codecs. Open the clip in VLC, open the Info window, toggle the triangles on the left of the Stream 0/Stream 1 lines.
    - "mpga" for MPEG Audio, usually MP3 (for AVIs)
    - "a52" for AC3 (Dolby Digital) audio.
    To plackback AVIs with AC3 audio in QuickTime Player, install the AC3 component.
    Mar 2006
    I have the ac3 component installed... But after it is unzipped, it says there is no default application to open it with. What should I open it with?
    Thanks!
    veganjustice
  8. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Move it to /Library/QuickTime/
