I have here a DivX encoded AVI file with 2 audio tracks. I can switch between German and English language when playing the AVI file with e.h. Media Player Classic. Moreover I have a subtitle text file (SRT) for the English audio track of the AVI.
I would like to convert the dual-audio AVI incl. the SRT file to DVD format incl. both audio tracks and subtitle support.
Question: How can this be done in an easy, uncomplicated and quick way (one button solution) ? SVCD2DVD (latest registered version 2.1.2284) does only recognize the first audio track in the AVI and afaik subtitle files are not supported ?
Best regards,
Joerg@JoergChristoffers.com
A search would have shown you that subtitles are supported:
https://forum.videohelp.com/viewtopic.php?t=278319&highlight=subtitles
Is the audio two separate streams or do you have single stream with different languages on each channel?Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
Dual or Multi Audio AVI with subtitles (MPEG4 XviD DivX)
By DereX888 in forum User guidesReplies: 16Last Post: 20th Dec 2012, 16:24 -
Dual audio streams in an AVI file
By edwardcr in forum Newbie / General discussionsReplies: 3Last Post: 19th Dec 2010, 09:33 -
burning mkv file and separate srt file to play on dual layer disc
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 12:26 -
Easiest software to convert Dual Audio/Subtitle MKV to WMV or AVI
By greasyspoon in forum Video ConversionReplies: 1Last Post: 9th Sep 2009, 13:43 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 18:11
