Help. What is the maximun file size the TEMPGE will convert. Tried converting a 4 gig with no luck. Tried a 2 GIG and it still would not convert the entire file. Am I doing something wrong or is there a size restriction.
Thanks All............
When I've capture avi, I do it with Virtualdub, using multi segment. That way you can capture very long clips, and vdub cuts the avi file into 2 gig pieces, as many as needed.
Then when you load them into vdub, they merge perfectly. When I've done this, I just frameserv to tmpge, and I haven't had any problems with it..
So basically what I'm trying to say, do you capture and frameserve through virtualdub? You shoult try it otherwise.
davidian - obviously overestimating himself -
If you are using Windows 98 with FAT32, then yes, there is a file size limit of 4gig. This is the fault of the operating system, it is not the fault of TMPGenc.
Windows 2000 and XP do not have a 4gig file size limit if you use their NTFS file system. I moved up to Win XP from Win 98 to get away from that 4gig limit, and I must say, it was worth the upgrade to have the convenience of working with one large file instead of a bunch of chopped-up 4gig sections.
How do I convert 60fps to 30fps to halve file size?
By DigitalOxygen.ca in forum MacReplies: 33Last Post: 11th Jul 2012, 21:27 -
convert compressed avi files to mpeg without increase in file size?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 7Last Post: 2nd Nov 2011, 05:29 -
Best way to convert DV file to something that have smaller file size
By Cazz in forum Video ConversionReplies: 27Last Post: 8th May 2010, 06:14 -
Is There A File Size Limitation to Convert .ts?
By toddon14th in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2008, 23:04 -
convert video and detemine file size
By YOURCONNEXX in forum Video ConversionReplies: 1Last Post: 4th May 2008, 00:12
