In the past, I usaually re-encode the AVI to add Chinese subtitle because my DVD player Philips DVP642 does not support Chinese. It took looooong time in my old PC. Now I found a good tool call AVISub, it creates an .Divx file after processing. It takes only a few minutes to add max. 3 subtitles in to AVI movie. This .divx file can be played in DVP642 and I can switch over between different subtitles. Anyway, the subtitle is not very clear. Anyone use a better tool? VirtualDub do not have such function.
From the screenshot it appears to let you pick the font used to create the xsubs. So try picking a more clear font.
How to add permanent subtitles with AutoGK and convert to AVI DivX or XviD
By Baldrick in forum SubtitleReplies: 263Last Post: 17th Jun 2018, 16:18 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 13:52 -
It is possible to add chapters in divx dvd ? subtitles ?
By carl25 in forum Authoring (DVD)Replies: 7Last Post: 3rd Jul 2009, 00:06 -
How to add subtitles?
By jonhal in forum Newbie / General discussionsReplies: 6Last Post: 26th Apr 2009, 12:58 -
Add subtitles in HD TS file
By pdurand in forum SubtitleReplies: 3Last Post: 9th Nov 2008, 07:56
