    Apr 2006
    Ireland
    hi,
    I'm looking for a program for converting VOB files into .avi
    I have already tried imTOO dvd ripper but the picture is too small-
    i.e the black widescreen lines at the top and the bottom are too big.
    i'm looking for a program that would
    1. let me choose my ouput size (e.g. 350mb for 42min of vdeo)
    and
    2. let me keep the resolution of the vob i am converting.
    thanks for any help in advance!!
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Virtualdubmod or virtualdubmpeg2 will do the trick
    Feb 2004
    Australia
    Check out my frameserving guide for vdub , all you need for that .
    this allow's for some filtering and modification of codec's used to compress .
    Or good old dvdx (people forget about it) ... not as feature rich , but simplest .
    Apr 2006
    Ireland
    i downloaded virtualdub 1.6.14 and it won't open VOB files.
    is there any way to fix this?
    Jul 2001
    Read Yoda's message again. You didn't get either item he recommended.
    You could also use dvd2avi and use TMPGenc for your encoding. Good old standby when all else fails for me.
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
