Hi all
I have a presentation done on powerpoint that id like to put onto dvd is this possible and if so does anyone know the best software to use, or of any other software i could make the presentation with to burn to dvd, its just a few pages of txt id like to scroll down the screen with a few pics and a menu.
cheer fusion99
Forum search and Google must have been broken
http://www.ppt-to-dvd.com/
Wondershare produce this program called powerpoint2DVD, but I noticed it's been removed from the tools section here, probably due to the constant spamming and abuse by ingrates connected to the company.
Another method would be to set up the powerpoint pres to run via timings and using screengrab software such as camtasia to "capture" the presentation.If in doubt, Google it. -
What I'd do is to export my Powerpoint presentation to jpeg slides and then write an Avisynth script to read in and then create a slideshow. You could then encode, author and burn and have your presentation on DVD. If you don't know Avisynth, the learning curve is high though ...
If you don't want to go the Avisynth route and have some other package that makes slideshows you could important the jpegs into that package.
How to add a DVD video to a Powerpoint Presentation
By andy jackson in forum Newbie / General discussionsReplies: 3Last Post: 17th Feb 2012, 12:27 -
how can i convert a powerpoint presentation and put it on dvd
By shashgo in forum Newbie / General discussionsReplies: 7Last Post: 8th Oct 2009, 03:14 -
Question about cutting clips for a Powerpoint presentation
By tanealbhandari in forum Newbie / General discussionsReplies: 16Last Post: 10th Dec 2008, 10:38 -
Powerpoint Presentation to Video/DVD Software
By Nasho23 in forum Newbie / General discussionsReplies: 2Last Post: 10th Apr 2008, 23:59 -
Which video format works best in a PowerPoint Presentation?
By foochuck in forum Video ConversionReplies: 1Last Post: 4th Oct 2007, 09:54
