quick question, i have a 47" Sony Rear Projection HDTV with a DVI input. is it worth it to buy use an HDMI to DVI adapter and purchase a new HDMI DVD player, or, alreay in use is the HDMI out on my Digital/HD Cable box to the DVI input on the TV. Is the picture quality on the DVD that much improved with the "UPCONVERSION" or should i stay with the component inputs from the DVD player???
Thanks---DL
i have the same circumstance...dvi input on hdtv but not hdmi. when i first bought the tv
i had the comcast/motorola hd dvr cable box hooked up with a regular dvi cable and
worked awesome...then 6months later comcast encrypted channels with 5c (HCMI i think) and
my tv would not receive a signal..just blue screen and audio BECAUSE the TV lacked decryption
through an HDMI port. Spent all that money for a digital signal and now have to use component
cable instead. however, since it's only a 34in widescreen, the component video looks every
bit as good as the digital did...with the one noticeable exception of a little darker on background
dark areas (like hd widescreen baseball shot of stadium the far away bleachers not as bright).
if your set is 50in or less, component will probably look damn near as good if you're at least
10-12ft from the set.
let me know what you figure out..curious.
thanks, mike -
i am actually more curious as to the UPCONVERSION from a DVD player with HDMI.......i have my COMCSAST Digi box currently hooked up the way you describe and notice a little better pic than component.
i just want to know if it is worth the money on a new DVD player for the UPCONVERSION.....
PS--i am using a SONY 47" widescreen rear projection HDTV w/DVI.... -
I have a 50" Sony HD RPTV with HDMI connection. Also an LGDVB418 upconverting dvd player with HDMI and an OPPO upconverting dvd player with DVI. Yes, there is a noticeable difference in picture quality, it's not a huge difference, but it is noticeable. If you spent all that money for a large HDTV, you might as well have the equipment to take advantage of it. I bought a cheap, manual switcher from marketeck: http://www.markertek.com/p/fullpage.php?page=037 to switch between my HD cable box and the dvd player. Works fine, go for it.
I love children, girl children... about 16-40
W.C. Fields -
thank you, i guess i am gonna buy a new DVD player on the way home and order a swtich!!!!!
well, it is all hooked up. got a nice sony dvd hdmi player at my favotire--UGH--place, best buy. currently hooked up with an HDMI to DVI adapter.
@ RICOMAN, i am gonna take your suggestion and buy a box and two HDMI cables, one for the DVD, and one for the Cable box, then run one DVI to the TV.....Thanks Again!!!!!!
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 17:20 -
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 09:31 -
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 20:32 -
Need help with HDMI, DVI-HDMI and "high definition audio device"
By uart in forum Newbie / General discussionsReplies: 7Last Post: 16th Mar 2010, 01:15 -
DVI - HDMI - DVI problem
By rbjt in forum Media Center PC / MediaCentersReplies: 0Last Post: 5th Aug 2009, 00:14
