I've just purchased an ASUS Pudit PE3 barebones PC. Very, very nice as it's nice and quiet and pretty fast when it comes to doing things. However, it has one major drawback in that it only takes half height PCI or PCI Express cards and I don't know of any capture cards that will fit.
So the question to all you wonderfuly knowledgable people out there is whether you can recommend any suitable cards. It doesn't have to be an all singing and dancing TV tuner etc. as a card that will accept video/audio in would be perfectly acceptable. So how about impressing me with your brilliance and coming up with a solution that I can buy in the UK or Europe![]()
Artificial intelligence is no match for natural stupidity.
Baldrick said:
I had hoped to get an internal card as I'm a little nervous about external units abilities to capture without degredation of quality or dropped frames. Just how good are they really?maybe an external usb2 device?
canadateck Said:
Errrrr! I did say in Euope but at least you have given me a Hauppage card that I can look for in Euopean sources. For that I thank you!Artificial intelligence is no match for natural stupidity. -
Just checked all Hauppage sellers that I could find (and used Google) and not one company sells the low profile WINTV-PCR 150MCE. I also gather that the one sold in the USA will be of no use to me since there is 2 versions, one for NTSC and one for PAL and the only ones sold in the USA are, big surprise
are only for NTSC.
Anyone else have any suggestions?
Baldrick (or anyone else) just how good are USB Capture units?Artificial intelligence is no match for natural stupidity. -
I use the Hauppage WIN PVR USB2.0 and I am very pleased with it.
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 11th Jun 2011, 00:05 -
What's new in capture cards for VHS capture?
By chowmein in forum Capturing and VCRReplies: 21Last Post: 29th Jul 2010, 09:03 -
PS3 playback of MKV 1080i, 25fps > 23.976 source to BD plays at half height
By Zot in forum Blu-ray RippingReplies: 0Last Post: 29th Mar 2010, 18:00 -
Using 2 Hauppauge Capture Cards
By ddpool58 in forum Capturing and VCRReplies: 35Last Post: 21st Aug 2009, 22:53 -
Help with Video/Capture Cards.
By drsimp12 in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2007, 07:05
