I hate to asking this, because I'm sure one of the main answers would be 'try them...' or 'it depends!', but I am updating my PC on the 'DVD9 to DVD5' issue and, looking on the net, I have read many people speaking of DVD Shrink and DVD2One.
(I can't consider DVD Revuilder because it takes too much disk space - about
4 Gb of temp space - and I cannot afford to run it, on my PC. I need a transcoder, not a re-encoder).
I would have only this question, and I hope someone someone more experienced than me can answer me (once he/she knows that the quality is my top issue, and time is not): I cannot decide among last version (3.2) of DVD Shrink (with all the quality enhancements like 'perform deep scanning analysis') and DVD2One v2.
Now, let's suppose that I only want to shrink the main movie on a DVD5 (that is, removing all extras from the DVD).
I also have heard that, only DVD2One, if might happen that some unwanted stuff (like FBI warnings or logos) remains, taking extra room on the DVD. Is it true?
Therefore, my question is: to make a 'movie only' backup, what would be better?
A) DVD9 --> DVD5 with DVD2One (maybe, having last version of AnyDVD in the background, to have high DVD decrypting power).
B) movie-only with zero compresson with DVD Shrink (having last version of AnyDVD on the background) [DVD -> DVD without extras on my HD] + further compressing of the movie movie (> 4.3 GB) --> movie (4.3 Gb) with DVD2One.
C) simple use of DVD Shrink for both 'movie only extracting' and 'shrinking'.
Could someone give me some suggestion, please?
DVD Shrink with Deep analysis and AEC is about as good a transcoder as you can get. If you don't have the spce to encode, don't waste space on software you don't need. I would stick with Shrink.
Read my blog here.
I agree with guns1inger. DVD Shrink has the ability to choose what you want to keep much more than DVD2One and has better file reducing abilities if you are after higher quality. However, if you mean what you say about time not being an issue but quality is then you really would be better off using a re-encoder.
Artificial intelligence is no match for natural stupidity. -
90% of the time I use Shrink. It is more versital in most instances. However, 2to1 does have it's advantages. It is more forgiving. It will take vobs and ifos with problems and give you a working transcode when shrink balks. 2to1 also has the ability to do a seemless join which on occasion is a nice feature. Also another useful program that is quick, it requires no transcode, is Title set blanker to remove those annoying items from a dvd close enough to be transferred to a dvd5.
Originally Posted by aldaco12
Basically it comes down to using DVDShrink or DVD2One in Movie Only Mode. All things being equal, DVDShrink gets my vote.If in doubt, Google it. -
#1- I first resize or remove the stuff i want with DVDshrink.
#2- Then refine the editing and or use the join feature if i want with DVDRemakepro.
#3- And finally: I use DVD2One to do the final resize to 4.36GB.
I get nice results. -
DVD2One is said to give slightly better overall quality than shrink
Does it or doesn't it ? If you think it does, go for it. If you are using it because someone else says it does, but you can't see the difference, then you are just wasting time. There are some here who say that shrinking any movie with DVD Shrink to 50% of it original size will have a visual quality the same as the original. Would you take them at face value ? (I wouldn't. They are obviously a. Insane, and b. Blind - probably from doing the thing that drove them insane)Read my blog here.
Google is your Friend
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 10:00 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 10:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 06:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 16:11
