Are there any programs available that would allow me to combine a mp3 song with a home video.
thanks
What do you want to get out of this at the end of the day ?
If you just want an avi file with your audio and video together, virtualdub can do this pretty easily and quaickly.
If you want something else, you will have to give more detail.Read my blog here.
thanks I will take a look at virtualdub. do you know where to locate a guide on combining AVI with Mp3?
I'd actually prefer virtualdubmod for this task, as the streams list makes this task relatively easy for even the most amatueristic novice IMHO.
Open the video, then go to Video > Direct Stream Copy. Then go to Streams > Streams List, click the Add button, browse to your file. Right-click on it and make sure it's in Direct Stream Copy mode, then go to File > Save as AVI.
Sadly I think they took the streams list out of the latest version
If in doubt, Google it. -
Yeah, and if you need to adjust the sync of the audio and video, in the audio interleaving options, there's a delay setting (negative number for late audio, positive for early). Or, for more precision, you can go with Adobe Audition, load the video into one stream, turn off the stream with the video's original audio, load the mp3 into another stream, and line it up visually that way. then export the audio. I go this route when using mp3s for music videos.
Combining Image and Video
By black5 in forum Newbie / General discussionsReplies: 4Last Post: 5th Aug 2010, 20:41 -
Combining a single picture with an mp3 to create video file
By mark1111 in forum Newbie / General discussionsReplies: 2Last Post: 7th May 2009, 05:13 -
Combining video and subtitles...
By jpresto in forum Newbie / General discussionsReplies: 1Last Post: 28th Jan 2009, 19:43 -
Combining Powerpoint and Video
By gurot in forum EditingReplies: 3Last Post: 16th Dec 2008, 20:38 -
Audio and Video not combining
By adeleander in forum ffmpegX general discussionReplies: 9Last Post: 23rd Sep 2008, 16:52
