  1. Member DVWannaB's Avatar
    Dec 2001
    HELP!!!!
    All, I have a DVD+R DL disc that I am trying to make a copy of. Not to worry, it is home-made and originally authored by me. All efforts to rip to another disc has failed. I have used DVD Decrypter, DVD Shrink and DVD FabDecrypter and all have run into problems I believe at the layer break. They all read and copy eveything up to the third VOB file and then gives an error. I have a strong suspicion that the media I used is causing the problems. It is a Dysan brand (Ritek) disc.
    Is there a method that I can use to extract the files despite the layer-break issues? I already have some Verbatim standing by to replace the crappy Dysans.
    Aug 2002
    cleveland, oh
    Since the DVD is not copy protected treat the disk as any other removable media. Just use windows to copy the folders to your HD. then burn a new DVD.
    If the third .vob wont read then you are OOl.
  3. Member DVWannaB's Avatar
    Dec 2001
    ISObuster seemed to work. Not out of the woods yet, but will post my final resolution.
