I installed a Lite-on DVD burner with lightscribe a couple of weeks ago. After about a week it stopped reading dvds. I was getting an error " unsupprted format". I rebooted and it worked again for a few days. Yesterday I put in a dvd and I got nothing, no error message. When I clicked on My Computer and Open on the drive the file was empty. I then tried my samsung dvd rom and the same error came up " unsupprted format". I did an uninstall in device manager and rebooted and the Lite-on works now. The samsung still wont work. Anyone know what the problem could be ? There are no firmware updates for the lite-on. It is a SHM-165H6S Ram. thanks
Are the drives on same IDE channel, and are drives set as master or slave per instructions if documentation specifies such settings? Some drives specify master or slave setting and may not work properly if not set according to specifications.
DVD Shrink and DVD Fab stop working
By Snowdog2112 in forum DVD RippingReplies: 4Last Post: 19th Oct 2010, 10:48 -
Why does doing video editing make other apps stop working?
By brassplyer in forum EditingReplies: 7Last Post: 13th Aug 2009, 11:01 -
Stop working and can't get it to work again...
By stillstanden in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 30th Jun 2009, 00:00 -
All my blu-ray and dvd drives stopped working.
By Obamargarine in forum ComputerReplies: 6Last Post: 20th Feb 2009, 20:39
