my verbatim + DLs will playback on my apex player, but not on sony. is this strictly a disc issue, or would writing method matter? i.e. if i write w/ nero, would playback differ when writing w/ DVD decrypter or another program (resulting in higher compatibility?).
thanks
Results 1 to 10 of 10
Yellow-Haired Warrior...Go
+R D/L playback compatibility is a pain in the butt.
Sony's playback abilities of recordable media is a pain in the butt.
Nero vs. DVDDecrypter?
I'd pick DVDDecrypter hands down. -
I have the old flagship the SLD-7700 Sony. It sometimes play the disc and sometimes it does not.
The Philips 642 that was $60 plays everything like the computer DVD player. On a 32" TV, the Philips looks just as good as the Sony. -
sounds subjective, do you have evidence that either one allows for better DL playback compatiblity?Originally Posted by "hech54Nero vs. [url=https://www.videohelp.com/tools?tool=DVD_DecrypterYellow-Haired Warrior...Go
For starters.....a D/L to D/L backup/copy done with DVDDecrypter will be an exact copy of the original...including the layer break but minus the protections placed on the original...if there were any in the first place.
Secondly....DVDDecrypter allows for bitestting of +R discs(if necessary or required)...though only on certain makes of DVD Burner. The latest incarnation of DVDDecrypter(the one that only burns) is probably even better than DVDDecrypter.
See:
ImgBurn -
Looks like Sony is very sensitive. I have Sony DVP-NS725P ($100.00, BestBuy).
I have also CyberHome CH-DVD 300 ($39.99, BestBuy). I bought it for the reason of testing back-ups. CyberHome plays those disks that Sony can not take and quality of picture is way better: its sharper and juicier.
The ONLY problem with CyberHome is that its taking long time (around 1 minute) to load disk. Sometimes you would need to re-insert it.
taboo -
Did you set the bitsetting (booktype) to DVD-ROM before burning? You can do it with CD/DVDspeed. Some standalones are better that others at playing DL media.
I love children, girl children... about 16-40
W.C. Fields -
hello hech54,Originally Posted by hech54
On DL backup with only main movie will be the layer break at same place as on original?
TIA
taboo -
It should....or it is supposed to. I've never tried anything else than a straight D/L to D/L copy with DVDDEcrypter.Originally Posted by taboo
The settings can be found here in DVDDecrypter:
Tools – Settings – ISO Write Mode – Layer Break (for DL Media ) – Calculate Optimal -
well thanks for all the replies hech54 and every1. i usually do only main movie + some extras w/ my backups, so DVD Dec. doent make an exact copy (i usually dont use iso read). and i have my benq 1640 set to bitset for DVD-ROM.
maybe i'll try to do "Heat" w/ DVD Dec.Yellow-Haired Warrior...Go
Sony BDP-S370: .mkv Playback Problems
By MWisBest in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Jan 2017, 01:54 -
Sony BDP-S270 AVI Playback Issue
By mxavier in forum DVD & Blu-ray PlayersReplies: 11Last Post: 10th Dec 2012, 13:40 -
I know this get's asked alot, but best playback on my Sony Bravia
By kbphoto615 in forum Video ConversionReplies: 3Last Post: 23rd Oct 2011, 02:39 -
Mini DV recorded on Sony does not playback on JVC (but opposite does)
By joweyenb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 6th Feb 2009, 07:39 -
Sony S-Master and fuzzy/staticy playback
By NES_Master in forum DVD & Blu-ray PlayersReplies: 2Last Post: 11th Aug 2007, 19:58
